音效卡能取代 CD-player 嗎?
音效卡能取代 CD-player 嗎?
文章MoLtoSoLo 發表於 週日 11月 23, 2003 7:14 am
我以前一直不相信音效卡的聲音會有多好, 一直到今年的 VSAC 聽到了 Cain&Cain 的喇叭加上 "VRS Audio System" (a computer based digital source), 我才發現電腦的聲音可以這麼好.
人家是 high end, 整套大概五六萬美金吧. 不過好的 soundcard 也跟高級一點的 CD player 比起來也不太貴.
也許有一天音效卡會取代 CD-player 吧.
有人有經驗可以分享嗎? (成功或失敗都可以) :)
http://www.6moons.com/industryfeatures/ ... sac_6.html
(中間的部分)
Terry Cain of Cain & Cain threw those who consider single-driver speakers and single-ended tube amplifiers archaic anachronisms a majorly sliced fast ball not by making really good sound nor by showing with his personal Electron Luv Electronics. Nyet. For his digital front-end, he instead used a computer-based hard-drive server by Las Vegas/Nevada based Vince R. Sanders of VRS Audio Systems. That got people's attention. By eliminating a laser pickup, read errors and jitter and assembling the best sound cards, internal DACs, wiring and connectors possible, percussionist Sanders claims that his $4,000 digital Audio RPC sonically outperforms even ultra-expensive two-box digital transport/DAC combos. Terry visited the man in Las Vegas to put big claims to small ears. Seeing the (blue) light, he instantly purchased a unit on the spot, adding dryly that more than one of his dealers has followed suit since sans regrets. Computers, Fostex and SETs - talk about convergence!
With 16dB of headroom, the internal gain structure is high enough to run the unit's analog outputs amplifier-direct. The aluminum casing can be anodized in any color desired or finished in wood grain. With provisions for four internal hard drives (currently 80GB serial ATAs but Western Digital has 250GHz hard drives on the burner), Sanders recommends a $899, 10" ViewSonic Airpanel as the wireless touchscreen interface to access the drive's uploaded software in the listening seat without interacting at all with one's main computer station. Uploads occur via the RPC's on-board Plextor drive which Sanders considers the ultimate audio extraction platform. In secure mode, 74 minutes of audio take 15-20 minutes to be imported, but 1st mode can reduce the protocol to 2-3 minutes. Current order lead times are 2 weeks and the designer works one-on-one with clients to customize the RPC according to their needs.
MoLtoSoLo
註冊時間: 週一 2月 10, 2003 11:30 am
文章尚飯桶 發表於 週日 11月 23, 2003 10:05 am
小弟因有曲式分析與詮釋比較上的需求
不能一日無cool edit pro 與音效卡
對這個題目也超感興趣的說
文中似乎未提到訊源的詳情(卡不大可能是自製的吧?)
MoLtoSoLo 兄所聽到的也是圖上這套系統嗎?
酷到不行!
尚飯桶
註冊時間: 週二 3月 04, 2003 12:52 am
文章steel 發表於 週日 11月 23, 2003 11:14 am
銀白色的管機...好像煉"仙丹"的爐 :D
真的很cool...
steel
RS2
RS2
文章: 3142
註冊時間: 週日 3月 09, 2003 3:04 pm
來自: 高雄市
文章尚飯桶 發表於 週日 11月 23, 2003 11:57 am
注意到網址了
那是show room!
我以為是在家裡說
陽光那麼好!
那管機看起來像"五州製藥廠"的設備 :D
尚飯桶
文章MoLtoSoLo 發表於 週日 11月 23, 2003 2:51 pm
這是今年的會場. :)
我覺得這個管機的作者星際大戰看太多了.
作得都像太空船一樣.
看看他做的喇叭.
http://www.positive-feedback.com/Issue9/vsacdr2.htm
第二張
J@ck 將是我的新名字, 將於二月份新年後開始使用.
MoLtoSoLo
文章MoLtoSoLo 發表於 週日 11月 23, 2003 2:54 pm
尚飯桶 寫:小弟因有曲式分析與詮釋比較上的需求
對這個題目也超感興趣的說
酷到不行!
我和他 Mr. Sanders 通過電話, 他說你愛用那張 Soundcard 都可以, 他蠻推薦 RME 96/8 PAD 的.
MoLtoSoLo
文章尚飯桶 發表於 週日 11月 23, 2003 11:29 pm
MoLtoSoLo 寫:
對這個題目也超感興趣的說
酷到不行!
RME 96/8 PAD 500多元,還好
基本上這等卡與1000元,甚至2000元的CD player 一較長短
依小弟的經驗與淺見來說
絕無問題
至於Mr. Sanders 所說的
「By eliminating a laser pickup, read errors and jitter and assembling the best sound cards, internal DACs, wiring and connectors possible, percussionist Sanders claims that his $4,000 digital Audio RPC sonically outperforms even ultra-expensive two-box digital transport/DAC combos.」
有沒有吹牛
那就不知道了
不過就算是吹牛
也不至於太離譜就是
不知道會場上用的是那一張"the best sound cards"
又所謂的 internal DACs 應該是指卡上的
不太可能把DAC裝到PC case (好像是CoolMaster)
小弟的 AKM4395VF 已經買來晾好久了
一直還沒動手把卡上的 4393 換下來
有機會再跟大家報告
基本上這個問題:音效卡能取代 CD-player 嗎?
小弟認為答案是肯定的!
尚飯桶
文章viaviavia 發表於 週一 11月 24, 2003 12:18 am
資訊廠商毛利越來越低,為了進入家庭電器用品這個更大的市場,資訊與家電整合的時代是遲早的事而已。
音效卡用發燒料去做聲音好不好?可以跟大家報告一下,整理一下 crystal 4297 這個非常通用的音效卡 chip 的電源,以及後面的 op 輸出電路,輸出品質好的很難想像。
誰的錯,大家的錯。你要買便宜的音效卡,廠商當然要使用爛 op 跟爛電容、電阻,品質能好就真的有鬼了。
討論音效卡改裝的網站
http://www.gen6991.idv.tw/
viaviavia
友站的站老大
友站的站老大
註冊時間: 週五 9月 12, 2003 4:46 am
文章MoLtoSoLo 發表於 週三 11月 26, 2003 12:14 pm
Cain & Cain 的老闆告訴我說他也不知道裡面是什麼卡, 我想 $4000 usd 的機器裡面應該是 Lynx Two 之類的吧.
我想, 要把電腦弄好聲不難, 組件市面上都有, 大家都買得到, 用點心就好了.
MoLtoSoLo
文章viaviavia 發表於 週三 11月 26, 2003 6:32 pm
要有決心花大錢啊,這點很重要。:P
討論音效卡改裝的網站
viaviavia
友站的站老大
友站的站老大
文章MoLtoSoLo 發表於 週四 11月 27, 2003 5:49 am
我自己花了約 $500 USD 來升級我的 P3-933 老電腦, 目標是 $1000 USD 以下的 CD-Player, 包括之前在 Head-Fi 聲名大噪的 Hot-Rod Sony SCD-C555ES. 過一段時間再來說說結果.
MoLtoSoLo
文章TJJ 發表於 週日 11月 30, 2003 3:59 pm
上面各位仁兄是否知道一個好聲的條件就是聲音要乾淨音效卡再好,還是要有好的電源,好的工作環境,才能發揮對細節的詮釋,所以個人經驗覺得CD PLAYER還是比較容易做到好音質的條件,不知大家認為呢?
TJJ
註冊時間: 週六 11月 29, 2003 9:37 pm
來自: 台南市
文章foo 發表於 週日 11月 30, 2003 6:34 pm
要把電腦的雜訊處理掉
不是花大錢,就是會搞得自己很累
搞的出來,效果或許會不錯
但是最怕是搞了半天,還debug累的要死
不如直接買player還快一點
foo
註冊時間: 週日 12月 29, 2002 8:20 pm
文章尚飯桶 發表於 週一 12月 01, 2003 4:07 pm
TJJ 寫:上面各位仁兄是否知道一個好聲的條件就是聲音要乾淨音效卡再好,還是要有好的電源,好的工作環境,才能發揮對細節的詮釋,所以個人經驗覺得CD PLAYER還是比較容易做到好音質的條件,不知大家認為呢?
這些專業的卡對爛電源、爛的工作環境都有免疫力(看實測規格與小弟個人聽感都如此)
不知怎麼做的
真是厲害
如果沒有免疫力的話
要賣這個價格
恐怕連一張都賣不掉 :x
尚飯桶
文章andy236 發表於 週一 12月 01, 2003 4:21 pm
尚飯桶 寫:RME 96/8 PAD 500多元,還好
依小弟的經驗與淺見來說
絕無問題
....刪....
可以把1000元,甚至2000元的CD player的廠牌及型號報出來嗎?
讓我等長一長見識 :)
宇宙最窮的電腦軟體人,現在只想好好聽音樂 閉關中
andy236
文章: 1909
註冊時間: 週三 12月 13, 2000 9:46 pm
來自: 天上山下
文章JackChen 發表於 週一 12月 01, 2003 4:40 pm
看背面的接頭好像是Lynx Two的樣子@_@以前有考慮昇級想買,最後還是把88MT當了,跑去買LCD了 :D
JackChen
註冊時間: 週六 9月 13, 2003 1:00 pm
來自: 台灣
文章尚飯桶 發表於 週一 12月 01, 2003 4:49 pm
andy236 寫:
依小弟的經驗與淺見來說
絕無問題
....刪....
讓我等長一長見識 :)
1000元等級小弟的經驗是Rotel RCD-1070,971
2000元等級是小弟的淺見,預測的,看看就好
Stereophile 上有一篇文章也可參考一下
http://www.stereophile.com/accessoryrev ... index.html
尚飯桶
文章Jeff 發表於 週一 12月 01, 2003 5:11 pm
andy236 寫:
依小弟的經驗與淺見來說
絕無問題
....刪....
讓我等長一長見識 :)
這是講美金....
Do It Yourself~
Jeff
AA 的老闆
AA 的老闆
文章: 2705
註冊時間: 週六 3月 24, 2001 6:09 pm
來自: 無聲的所在
文章MoLtoSoLo 發表於 週二 12月 02, 2003 2:40 am
http://www.avsforum.com/avs-vb/showthre ... 96%2F8+PAD
dCS Delius 24/192 D/A Converter, costs £6,000
Lexicon MC-12B Music & Cinema Processor, costs £9,000
http://www4.head-fi.org/forums/showthre ... adid=49754
alexerwu wrote:
The RME source replaces/renders obsolete some of my previous equipment (Linn Karik, Sony 9000ES DVD, Birdland Audio Odeon lite DAC, Philips 963SA DVD). In addition, I will go out on a limb and say that it (the RME) compares favorably in many ways with the performance of some mega-buck audio gear that I have heard on CD playback (Linn CD 12, DCS Verdi/Elgar combo). However, take this last comment with a grain of salt as I have not personally owned Linn CD 12 or DCS Verdi/Elgar combo nor have I heard these sources in my own system.
That said, I would say that within my limited realm of experience the RME card gets my highest recommendations as a digital source.
MoLtoSoLo
正在瀏覽這個版面的使用者:沒有註冊會員 和 43 位訪客
