EFM - 光碟數位音響系統的調製方法
EFM - 光碟數位音響系統的調製方法
文章soundtw 發表於 週日 12月 30, 2012 12:27 am
EFM - 光碟數位音響系統的調製方法
EFM - The Modulation Method for the Compact Disc Digital Audio System
作者:
HIROSHI OGAWA
Sony Corporation, Audio Technology Center, Tokyo, Japan
AND
KEES A. SCHOUHAMER IMMINK
Philips Research Laboratories, Eindhoven, The Netherlands
摘要:
The modulation method employed in the Compact Disc (CD) digital audio system codeveloped by Philips N.V. (Eindhoven, The Netherlands) and Sony Corporation (Tokyo, Japan) is described.
This method, called eight-to-fourteen (EFM), is an 8 (data bit) ---> 14 (channel bit) conversion block code with a space of 3 channel bits for every converted 14 channel bits which is used to connect the blocks.
These 3 channel bits, called merging bits, are selectable, enabling the suppression of the low-frequency contents of the frequency spectrum.
First some of the major conditions are listed which are required of the modulation method used for recording/reproducing digital audio signals on an optical disk.
The various parameters of EFM as a modulation method are explained in the second part, proving the suitability of EFM for optical disks.
An actual example explains the method in detail; a frequency spectrum is also given to enhance understanding.
EFM is well matched with the error-correction method CIRC employed in the CD.
The combination of these two methods plays an important role in stably reproducing a 2-channel 16-bit audio signal on a 12-cm-diameter optical disk for more than playing time, single sided.
來源:EFM - The Modulation Method for the Compact Disc Digital Audio System - Google 搜尋
http://www.google.com.tw/webhp?hl=zh-TW ... 80&bih=723
未完...待續...
soundtw
註冊時間: 週六 12月 29, 2012 10:08 pm
正在瀏覽這個版面的使用者:Bing [Bot] 和 61 位訪客
